Something like that - and before you ask let me tell you it's hardware authenticated (tied to the laptop you install it on)
To be honest mate I'm pretty much through with ideas of this and that might workIf I were you I'd ditch the ELM altogether. The ELM in theory should be able to connect without any software at all. You can use hyperterminal. The KWP2000/ISO14whateveritis interpretation is done on a PIC processor in the cable itself (which im sure you all already know). So if that chip cant talk to your ecu your stuffed.
There is some little known software called unidiag, this apparantly can talk to the edc15c7 ecu that is present in some Stilo JTD's using a definition file for the edc15c5 which is used in the Alfa 166. This works with a "dumb" cable, something without an interpreter chip, and the protocol interpretation is done on the computer itself, rather than the cable.
Ive had it working with my Punto HGT Euro2 and up until now nothing would talk to it. I built a very simple cable to do this (cost about 60pence) plus the price of the OBD connector.
It might be worth looking up the particular model of your ECU to see if it uses both a K and an L line, as AFAIK most fiats 97-2001 (pre OBD2) just used the K line.
That's right Frank (although it's more a case of talking with different codes which are not part of OBDII rather than actually converting anything). In the end it's all down to the software so as it works on mine then it must work with your 05 JTD.then im in the same situation as you. interface detected, atsi 'ok', atfi 'error'
lets hope they make fast progress. did they tell you what protocol the car uses?
so this means that the software needs to be configured to turn the garbage results into readable figures and that is what current software seems to do.
What version of ProScan are you using?(I'm using proscan with it which autodetected the car instantly)
Just got an ELM327 for my 53 plate Stilo JTD 115 and it works fine as far as I can tell (I'm using proscan with it which autodetected the car instantly). Can read error codes, show coolant temp, engine rpm, air intake temp, and loas of other stuff! Really pleased with it!!
If anyone needs any configuration information or anything else I am happy to help, or if anyone in the Whitley Bay area wants to test to see if it works then just pm me.
P.S. Does anyone know if the horsepower tests work using proscan as mine shows bang on 115 just want to know if it calculated them correctly and if the 0-60 speed tests work.
how do you fancy a road trip? lol
im near pontefract but would like to try it out on my jtd so could meet you halfway somewhere? will of course pay for an non/alcoholic beverage
my thoughts are though that it wont work but it is worth a try.![]()
Might be passing your way on my way to Norfolk on Friday night it will probably be around 6:30ish, could meet up at Ferrybridge.
Nothing yet - can still only read/clear fault codes.do you have an update on the gendan software?
For something to do have just tried this on mime :idea:Just got an ELM327 for my 53 plate Stilo JTD 115 and it works fine as far as I can tell (I'm using proscan with it which autodetected the car instantly). Can read error codes, show coolant temp, engine rpm, air intake temp, and loas of other stuff! Really pleased with it!!
