J jackwhoo Distinguished member Joined Apr 8, 2017 Messages 7,567 Points 1,762 May 15, 2023 #21 The cranking rail pressure is significant in relation to the starting problem Looking at your first readings the intake air temp should not be -40 degrees c Last edited: May 15, 2023
J jackwhoo Distinguished member Joined Apr 8, 2017 Messages 7,567 Points 1,762 May 15, 2023 #22 You could try unplugging the MAF sensor and seeing if performance improves-you will get a check engine light
OP OP Greasytrucker Established member Joined Mar 13, 2023 Messages 751 Points 308 Location Leicestershire May 15, 2023 #23 jackwhoo said: The rail pressure is significant in relation to the starting problem etc which is why we have been asking. Click to expand... Yep gotcha. Could that also explain the rough running when warm? If so are we talking high pressure pump?
OP OP Greasytrucker Established member Joined Mar 13, 2023 Messages 751 Points 308 Location Leicestershire May 15, 2023 #24 jackwhoo said: You could try unplugging the MAF sensor and seeing if performance improves-you will get a check engine light Click to expand... Still pulls fine, not really down on power and getting 49mpg so can’t see MAF being an issue
