certainly even though im not volxstu
http://caraudiosecurity.com/shop/product/products_id/7456.html
that will do you nicely
we need to know your sub configuration tbh
Sub configuration?
dont be sorry
volxstu is best for this im not to good but need to know if the subs are running in 2 or 4 ohms and if they are connected together or each one is connected to the amp separately
your better off with a monoblock amp then
If your a bit strapped for cash why don't you look for something second hand. You clearly need a bit of time to read up and learn a bit more otherwise whatever you buy is likely to be an expensive paper weight. So you have time.
I know it's tempting to jump in and have sounds ASAP but its not worth doing in the long run.
Of cause it will sink in. Once you have read up a bit it will make sense.
I don't always trust Local retailers. If it's a well respected one then you will come out with a good amp that is absolutely suited and at areasonable price.
9 times out of ten you will come out with some unmatching fli/ vibe/ edge rubbish because that is all they are allowed to sell.
You can tell a good retailer because they will have higher end stock. But this requires knowing what high end is to tell.
Find out what resistance your at and I'm sure we can help.
