alignment and camber
Essex/Suffolk border
got my new front suspension tops n bearings in the week, so Finlay got the fk coil overs on right. to day i went to http://www.elitedirect.com/ as recommended by GSR, they are a top place don't just set it too book but ask your driving style and tweak settings to suit :) only cost me £46 as i had got lucky and 1 side was set right to start with.
they also sell a huge range of wheels and have a cafe and a chill area bit with tv and sofas as well
Hey Dave,
I went to the link you listed and got a web search page. I need a way to adjust the camber on my x1/9 but can't locate any camber bolts or top plates for it. Can you guide me to a source for them?
thanks, Kirk
to adjust camber just drill out the holes on the suspension turret and add bigger washers. then use a magnetic camber gauge to make sure you get both sides even.
or you can pay a fortune for special bolts with thinner heads.
Hey Dave,
thanks, Kirk
i not sure what is going on with their website, think some one nicked the addy. i will investegate
got my new front suspension tops n bearings in the week, so Finlay got the fk coil overs on right. to day i went to http://www.elite-design.co.uk/ as recommended by oldschool, they are a top place don't just set it too book but ask your driving style and tweak settings to suit :) only cost me £46 as i had got lucky and 1 side was set right to start with.
what did u have at cafe?:yum:
Ahhhh, I think the special bolts with thinner heads or cammed camber bolts is more my speed :>) Do you have a source for any that will fit the x1/9? I have found many for the 124, 128 and 131s. Do you know if those will work for x1/9?
Thanks for the help!
Dave,
I had misread your post. My mistake, I thought you were referring to where you got the top plates but you meant the alignment shop.. Sorry for the inconvenience!
Kirk
A fellow on another forum advised that you can't use offset camber bolts on the rear x1/9 to correct excess negative camber because the hub hits the bottom of the strut which brings me back to adjustable top plates or drilling extra big holes and using larger washers :cool:
Sorry, not cutting up this one or letting a body shop bend anything to compensate for shorter springs. I could go back to stock springs but I'm sure this is a common issue with x1/9s.
Does anyone have a source for the adjustable top plates?
