Technical Air flow sensor
stescudo
Hi, can i still drive my Scudo van, with the Air flow sensor disconnected ? and if so why is it there ?
Hi, this should be on the thread you already started but.....
Yes you can drive with maf disconnected but the mil light should come on. If the mil light is on for maf disconnect you won't know if something more serious happens to put mil on.
Plus it will run better/more efficiently with a working maf sensor connected.
Do not get a cheap Chinese maf sensor they may put the mil out but will cause bad running.
Good luck
