guybusc
- Joined
- Aug 21, 2014
- Messages
- 77
- Points
- 34
The aerial on my car is a bit pants. Is it possible to change just the aerial itself without having to rewire to the radio?
Cheers guys but my oem aerial is right floppy where it hinges so I need the Base and the aerial itself. If I can change these bits without rewiring to the HU that would be great.
Any recommended replacements?
the mast on your car will unscrew from the base, just get a new mast with coil of wire around the outside and signal will be a lot better
from about £3 delivered on ebay
Like Dave says, pull/twist the top part off and tighten the screw. Push the top back on. The top is held by three tabs so easily clips back on. The one in the picture is broken at the hinge
what do you mean
Will something like this fit and work properly?
http://www.ebay.co.uk/itm/ACP-Unive...arts_Vehicles_CarParts_SM&hash=item43d26d6432
Shark fins don't really go well at the front of a punto as they usually go on the back end of a car roof, plus they normally get bad reception
Brad
