Technical  adjustments
I still haven't been able to resolve or even understand this problem, and no one I've spoken to has found what might be causing it yet..... It's just a Fiat, I can't believe there's no solution..... It's become a matter of principle to solve this problem, and by the way, as I mentioned earlier, the proxy wasn't working, but to my surprise, it worked this time, although it wasn't going through the dashboard previously.
Unfortunately, it still doesn't display the vehicle gear position, the odometer blinks, and the only thing left in the menu is the seatbelt buzzer.
Ha, so I assume there are still errors for the connection to the gearbox or dashboard modules?
I don't know what to look at anymore. There are no errors in the transmission, everything works, the dashboard too. It's a very strange problem, all the connectors are perfect, and the grounds are all normal
The NCR node is the robotized gearbox node.
That's a troubleshooting guide for the error NCR node absent just to give you an idea where to check:
I will attach the CAN connection lines E1050 doc in the afternoon.
That could be helpful, too:
I'm trying to get through the docs to find anything that could be related, but the server fails most of the time :(
So, the E1050 doc attached.
I'd check for ALL the connections, especially the ones between BCM, ECU and gearbox robot (M001, M010 and M054).
Continuity on both ends of the wire and resistance. Preferably also while moving the wiring loom.
More to go later on...
  • x198 Bravo eLearn - Electrical Functions E1050 Can Connection lines.pdf
I already checked all these lines of CAN, they are all normal, no break.
All the wiring I see and look at, it all looks very good, all the connectors look like new.
Yes, is the same error U1601 NCR node
I am already thinking, maybe the problem is with the robot module itself? how can i check that?
Could be, but you said it's shifting correctly as far as I remember.
There is no eLearn doc on diagnosing this particular module :( At least I couldn't find for the Bravo.
Besides, I'm not sure it's the gearbox module which is faulty, it also could be the NQS, or how they coded it, the display.
I already really don't understand where to look, yes, the gearbox works well......
I never saw NQS errors
It all started very strangely, possibly the problem was already there, but everything worked fine. Everything started after I wanted to remove the seatbelt buzzer and after that to perform the PROXY, and of course, it didn’t work out, and the odometer started blinking. I left and everything was working. The next day I wanted to try to do the PROXY again, and nothing worked, on the contrary, the gear position disappeared, and all the menu disappeared
