Technical Adaptive idle opening
Zwyczajny
Hello, is this good value? You got the same?
I believe not
I don’t use MES any more
But other maxed out signals normally look like that.
Look at the pre O2 signal. Does it look okay at higher revs then when you take your off the accelerator it creeps up.
My value for the adaptive idle is very similar to yours, mine is a 1.1 Eco. As far as I remember the value changed a little bit over time but was always about 6500%, my car was running well at this point!
I think that value ~6500 is signal to computer about programmingn value - DONE!
Car rur smooth, but got problem in first morning run. I have to turn the starter about 5 seconds before it starts the engine. :(
