Do you really think it would be a problem if they attached the plate in this fashion. I suppose you could just remove the plate and grease up the hole.
You're right, there are 4 holes for a fixing kit but i noticed that there was two small circles pre scored for what i can only guess is screws.
check to see how the rear number plate is fixed. is it using the supplied kit, four screws into the proper plastic lugs? or double sided tape? no worries, or is it two screws through the paint and metalwork?:bang:
Before signing any paperwork - which usually states you've accepted the vehicle as being in good condition - take a good look at the bodywork, checking for scratches, dents or imperfections. Sit inside and try everything, yes, everything. Make sure the washers wash, the wipers wipe and that the radio doesn't just power up, but will also tune in and play a disk. Test the horn, check the lights and, if they'll let you, take a short drive and be happy about handling, steering etc. Some of these we didn't do and regretted afterwards - such as finding a non functioning radio on the way home and having a wiper blade fall off first time it rained! People have reported very noisy heater fans, doors which won't lock, and really weird noises from the floor pans. If the tyres are wrongly inflated you'll likely feel it pulling to one side or the other. All a bit of a PIA, but worth if once it's done. Good luck, enjoy.Hi guys
Read a lot of advice here before buying - many thanks to you all.
I'm about to pick up my new Active Eco 1.1 - any advice on what to check for in the handover please?
Many thanks
Oga
maybe not, modern production methods, galanvised steel etc. but consider this, you lash out for a new car, do you really want the metal work screwed into, in such a fashion? just because it's at the less expensive end of the car buying scale, doesn't mean you have to have it like that. if metal is metal, and paint is paint, bentley would be dong the same, somehow though i think not.
after all if the fixing kit is there, in the glovebox, why not take the extra 10 seconds and do it how the factory shows you?
Sit inside and try everything, yes, everything. Make sure the washers wash, the wipers wipe and that the radio doesn't just power up, but will also tune in and play a disk. Test the horn, check the lights and, if they'll let you, take a short drive and be happy about handling, steering etc. .
I have to say I disagree. That's a waste of time. Check the paintwork etc but don't waste your time checking that the radio works because you've got a warranty to sort that out.
There are 4 screws attaching the number plate - guess they are self-tapping screws straight into the metal.
The garage we bought from was a long drive away for us. The main dealers were an even longer drive. The radio fault took over three weeks to get sorted. Horses for courses, but it could have been seen to on the day of collection thus saving me nearly three hours driving and a four hour wait on the day at a location miles from any shops or cafes. Oh, and a badly refitted roof lining begrimed with dirty finger marks too on collection. Obviously your mileage varies, the OP asked for advice, I gave mine :shrug:I have to say I disagree. That's a waste of time. Check the paintwork etc but don't waste your time checking that the radio works because you've got a warranty to sort that out.
if they are out in the corners, then they are using the lugs
If that be the case then they've done it right The lugs are not in a symmetrical posititionThanks for the pointer - they are towards the corners, but bottom right one is not in a symmetrical position (it's about an inch to the left of matching the others).
I haven't loosened the screws to take a definitive look, but they seem to be screwed into something plastic, hopefully the lugs you describe!
This doesn't illustrate it that well but you should be able to make out that the screws on the right hand side aren't exactly alligned, which is the way it should be
Always happy to help. It is a bit strange but as long as the plate stays on I'm not botheredYep! It looks just like that. Kinda shoddy-looking, had they been trying to be accurate! They must be avoiding a wiring loom or something. Thanks for the info.
