Technical  ‘98 Punto 1.2 ELX Cabriolet front window problems
Flyingsquirrel
To my shame, my wife’s punto has long had a non functional passenger side electric front window. Now, however, the driver’s side is now not working which means I have to address the issue.
The fuse to the system is ok, so long as the information I have is correct, so I removed the relay to test it - a green 8 pin ‘C071’, which actually contains three relays and a chip with associated components. I cannot find a drawing of this to be able to test it… has anyone a link to, or information about this relay?
In the absence of more information, I’ll start working from the other end - checking the feed to switches and whether motors are getting anything but normally I check the relays at the beginning just because it’s easy.
In hope…
