HeroicLeisure
- Joined
- Nov 14, 2009
- Messages
- 6
- Points
- 1
Greetings all, very glad to have found the forum. I'm hopeful you'll be able to help me work out what's going on and what I should do about it. It's to do with the oil pressure and now possible slight contamination of oil with coolant.
I've got an R reg 85SX 16V. It's been fab until very recently. Always run well, no real problems, low-ish mileage (50k or so), careful owners and well-maintained etc.
Current situation (since yesterday) is that the oil pressure light is now on all the time and - after an oil change - there's slight milky threads in the oil on the end of the dipstick (if I read the threads here correctly, that's suggesting some contamination, possibly coolant). But no obvious oil in water.
Before yesterday I was hopeful that the issue was quite simple. The whole history of the problem's development is like this ...
About 2 months ago the sump started leaking, corroded. Got a new one fitted. All seemed fine (although I'll admit to a slight suspicion that the engine sounded a bit more 'tappy' with the hood up, but dismissed it as paranoia).
Done maybe 200 miles since then, mostly 10-20 mile local trips. Runs fine. About 2 weeks ago noticed that the oil pressure light was flickering on when idling with engine warm. Checked the dipstick and noticed it was over the top limit (failed to check how far).
Took car back to mechanic - he dropped some oil out, pondered the dipstick, consulted something and said he'd put wrong grade in. Did a change to 10W (from thinner). I took car home and noticed STILL overfilled (about 0.5 - 1cm). Oil light on MORE often. Some discussion with mechanic - he'd not noticed engine as 16V.
Back to mechanic - he tried new oil pressure sensor - no change. Agreed to swap back to 5W oil, and correct amount. When collected car things in fact worse: pressure light now on just about continuously (except at high revs - 5k?! - he reported) AND slight milkiness in the new oil. After 24 hours standing this had disappeared from dipstick, but run engine for 5 mins and there are hints of it again.
Engine still sounds the same. No obvious oil in the coolant. No 'mayo' around oil filler.
Not being a real car techie, but having read around here, I'm wondering whether we're looking at a head-gasket issue, an oil pump issue, something else, or some combination?
I'd also like to know whether simply overfilling with oil after the sump change could've triggered these problems, even with only a little light usage, and why things got worse when swapped to 10W oil and stayed worse when going back to 5W. And it sounds a bit like he was thrashing the engine a bit while trying to fix this. Maybe it's all just coincidence that this happened after swapping to new garage (having moved) and it was all going to happen anyway? Not that I can turn back the clock ...
Given the car's age and likely low value (£500?), I'm wondering what sort of expense we're looking at here, given that I don't have the time nor real skills to do that much myself. What's the best way to suss out the problem without sinking good money after bad?
Over to you - your analysis and advice will be appreciated.
Mick
Mick
