so a motorad themo , comes with a 82 degree core that will fit a cinq ??
If they are different parts, then I doubt it.they are not the same for 899 and 1.1 , so do motorad do one more 899 ^^?
You go to a motor factor and ask them to get you a motorad 82 degree thermostat fot a Fiat Cinquecento. Motorad part number is: MR-284-82
No such part number, been to my factors today who got on the phone to Motorad who said that doesnt exist
_____OK guys, end of story for the thermostat transplant:
Ready made 82 degrees thermostat for the FIRE series from company Motorad (the one that introduced the failsafe/stuck-open-when-overheated thermo...). Code is MR-284-82.
This is the whole thermo system, not only the internal parts which we transplant.
There is also the classic 284-88 variation and a 284-71 one, which probably is mented for the Sahara desert...
The thermostat exists, my mechanic has a catalog from Motorad that includes them (along with MR-284-88 and MR-284-71), i'll try to get a photo tomorrow to show you. Perhaps your national Motorad importer thinks 82 and 71 degrees are useless for your colder climate and does not import them.
I will ask if i can get some thermostats from here and ship them to one of you. Let me get back on this tomorrow...
Just as an add on about thermostats.When I raced Ritmos here in Ireland ,back in the early 90's,most of the lads were running without thermostats.They just took them out of the housing and ran without them.But most suffered some sort of overheating problems.Ok these engines were touching on 9000rpm from time to time and were being raced but I think most people dont think about the working of these stats.First they are closed to allow the engine to warm up then open to allow for the engine to cool properly[we all know this]But they are also as a restriction to flow.Think about it this way,water speeding past your hot cylinders etc will not carry away much heat,but cause a restriction,slow down the flow and you allow the water to absorb all the unwanted heat and carry it to the rad.Here's the best bit I raced with a standard stat that had failed in the fully open position and never overheated.So you could try to just lock the stat open.here's another tip from racing if you find your car getting hot,knock on the heater to the hot setting your engine temp will drop 5 to 10 degrees.
