djrose007
Just wanted to say a BIG THANK YOU to the guys that have responded to my cries for assistance over the past few weeks.
As a result I got a clutch working and had good pointers for tailgate washer problems etc.
This morning I drove it to a local garage run by an ex-RAF mechanic mate to go through the MOT test so that I would know what I was facing. I did not expect a pass but thought I might get away with a £100 or so.
I got the dreaded phone call:
- DANGER point - fuel tank has a leak. new tank needed + fitting
- Emissions indicate the Cat Converter has gone. new needed + fitting
-Both sides front brake pipes dangerous and need replacement. And I drove it to the garage !!!!!!!!!
- low % brake efficiency on one side.
- Two tyres need replacement. lesser of other evils!
Minimum, including labour at very reasonable rate, £700.00 which I'm afraid just made it not worth while.
About the only thing that was ok was the clutch that I'd got working with the help of this forum !
End result is that I drove it about 100 yards to the scrapyard and got £60.00 for it, and I removed the new battery!
Thanks again for your assistance. If I, or a family member, ever own a Fiat I will be back. (My own car is the Mazda MX-5 Roadster Coupe 2.0i with the retractable hardtop).
Cheers
Dave
Cheers
Dave
