General 54 plate Stilo jtd just purchased!
ad777
Perth
Hi all, just bought this car yesterday...First fiat since the 80s! It's seems to drive very nicely, but when sitting at tickover ther seems to be a lot of vibration from the engine. Can I ask if this is pretty normal for these cars, or should I be investigating further?! Any advice greatly appreciated.
Muppet1
Springer Mad!!
Somerset
They do seem to idle a little rough, Well my 53 plate MW does, But soon settles down once on the move and warmed up.
OP
OP
A
ad777
Perth
Thanks for the reply. Mine seems to drive fine but as soon as I neutral there is a lot of vibration. I will investigate! Thanks again
Near the M4
The rubber mounts could be 20 years old..
My 2001 jtd wasnt bad for vibes.. so its not inherent :)
Where are you based.. ?
not many around Oxford area.. we had no Dealers in that era
OP
OP
A
ad777
Perth
I did wonder about engine mountings! Certainly worth a look.. This one is up in Perthshire I Scotland! Originated in Edinburgh I believe!
Ralf S.
Distinguished member
The land that time forgot
There's a wishbone mount that connects the back of the differential to the chassis... that I've seen mentioned over the years.
Mine (18 yo and 209,000) is the original but quite a few people have replaced theirs.
The other mounts are under the battery and over on the left next to the suspension turret. If you engine "moves about" when you rev it up a tiny bit.. then it's a mount.. just a case of working out which one(s).
Ralf S.
OP
OP
A
ad777
Perth
Thanks very much for that! Great advice, I will investigate at the weekend. Wasn't sure about the car but it is growing on me!
Muppet1
Springer Mad!!
Somerset
They do very much so, I got mine 5 and a half years ago, It's never failed me yet, Starts every time, Gets me where ever I want to go, Still does 50mpg and is comfy.
For a £600 car, she does very well. And is my 3rd Stilo MW Jtd.
Sure they can be frustrating sometimes but what car isn't.
OP
OP
A
ad777
Perth
Correct...nothing is niggle free! The only other wee niggle I have is how light the accelerator is...but found a thread where someone had attached a spring to it. If it keeps going the way it has I will be delighted! Will get a full service this weekend.
citroen john
warwickshire
Hi my 1.9 jtd is the same poor idle vibration,I have checked the right and left engine mount using a long screwdriver against my ear. With engine running place screwdriver onto engine side of mount and ear to handle then to body side of mount and you should notice a big drop in noise on the body side,if not jack up engine side or gearbox side just to take the weight and sit inside car to compare. Also there is the rear mount to consider, and the exhaust mounts ,the rear one on mine had failed,this change made a noticeable difference. Also check for fouls this is any item that has contact with engine/gearbox and body.
OP
OP
A
ad777
Perth
Great advice, thank you! I changed an injector last night, straightforward thankfully, now running on 4 cylinders! Much improved...but still could improve on vibration at tickover. I will try all you have suggested at the weekend. Thanks again!
