Pick me pick me......
Missing the parcel tray, the 'heater hoses' that go from the end of the black 'transmission' tunnel to the pipes that lead up to the screen vents, and I think the windscreen washer pump that sits to the right of the parcel tray. Also, I can see the fuel line in the top left of the picture. Looks like it is stretched more than it should be.
There are a couple of extra brackets I can see hanging down as well. Perhaps the previous owner removed the parcel tray to put a radio in?
Looks like the fitting for the washer pump is there but the rubber plunger is missing. Can't be repaired so needs to be replaced if you want it to work as per the original.
Fuel line should follow the wheel arch down to the floor panel and then across the front of the footwelll.
I have also included a photo of my accellerator pedal (69F), yours is very different.
Regards
