Technical 500 rear spring rate.
Anyone know the spring rate on stand rear springs 500F.
Hi Rizzo, The only info on common springs is noted in the 126 Haynes Manual - Chapter 10, spring identification - Yellow or Green type and then details on height under load for both colours. The rate is not detailed, Hope this helps.
Ian.
According to the Factory w/shop manual, the specifications of the rear springs are as follows:----Wire diameter:---------------------------13.5mm +/- 0.05mm
Working coils:----------------------------4-1/4
Free height:------------------------------221mm
Height under load of 410 +/-10kg:-----151mm
Height under load of575 +/- 29kg:-----123mm
Solid height:------------------------------93mm
Flexibility:---------------------------------17mm per 100kg
I think that the 'flexibility' factor might be the one you want----I would read that as 'spring rate'
Hi Lads,
Thanks for your input. Im fitting coil overs on the rear the spring rate is 200lb but it seems a wee bit soft. 7 inch long x 2.5 ID
