I have purchased an 09 plate 1.2 with 42000 miles on it, it had a fault code after less than 24 hours of ownership. The code is p0641. I know this relates to a voltage issue of less than 5 volts across a sensor. The battery and alternator have been tested and are fine.
I approached the seller who told me he’d just replaced the potentiometer and pedal as it had a fault code on it. I think I’ve been had over and he’s sold it with a known fault but my mechanic says the pedal is new and suspects the seller was fault finding then gave up and sold it to me. It drives normally then without warning it won’t go over 2-3mph. You can sometimes reset it by turning it off and on and it may go back to normal but not always. My mechanic best guessed the issue to the throttle body but a new one hasn’t cured it.
Any ideas greatly appreciated
