Technical 500 clutch mastercylinder to slave cylinder metal conector
cormik
Does anyone how the master cylinder pipe ,connects to the metal cylinder at the end of the slave cylinder pipe.
is it threaded or push fit!!!:):)
nothing in Haynes manual explains this
any help
any help
Do you mean this connection?
Google quick release clutch pipe, I posted the same question a little further back titled Clutch slave cylinder PIPE
Essentially you press in the white plastic section to release the splines
Thanks very much john
new to forum
did not want to just twist or pull,so thanks again for your help:):):)
