Technical 4x4 no ABS module in MultiEcuScan
MajstrCz
Prague
Hello dear Panda owners, after extensive brakes rebuild (including brake pipes), I took my 2008 1.2 4x4 for a test ride. After cca 3 kilometers it showed ABS and EBD failure, my suspicion was faulty connector on the rear left wheel, where I was also changing the sensor during the rebuils. However, the connector looked solid, so I ordered a green ODB extension and plugged it in. Unfortunately, MultiEcuScan was only able to detect power steering and engine ecu. I did a cross check on my Alfa where it detected the ABS unit flawlessly. I checked all the fuses. Does this mean that the ABS module itself has most likely just failed? Many thanks for any help.
Model
Climbing Panda 4x4
Year
2008
Mileage
99000
Hello,
Looking at the multiecuscan.net website it seems the green adapter is the correct one.
Can you see the power steering module? It seems that is requires the same green adapter. If so, that would be a proof the adapter is OK. If not, I would not blame the ABS module.
Have you tried scanning for errors on the body module?
I used the "Scan" feature to list the available modules first. Also the power steering module (and engine) appeared in the scan results, so the adapter seems fine.
Without the green adapter, can the interface connect properly to other modules? What kind of interface is that?
I assume there should be a fuse in the ABS system. Is the fuse OK?
What I've ment are you 100% sure it is OK, have you taken it out and swap for another one with the same current value?
More likely just a problem with MultiECUscan
The 4x4 uses stability control and later cars used the abs for hill decent
Your not the only person thats had problems connecting the 4x4 with the abs in MultiECUscan
EBD is critical, it's not safe to drive until it's fixed
If you have to brake hard the car will spin out of control
If the car had no problem with ABS originally it's almost certain it something you have done, when you changed the pipes did the ABS module run dry
Yes, it can connect and I think its Mobilly USB VAG OBD-II. Regarding the fuses I checked F87 and F23 (even by swapping with another).
The module did not run dry, we refilled and bleeded the brakes before connecting the battery.
The abs and steering are on different pins on a standard car
How the Abs communicate with the OBDII port depending on year, dualogic and so on
It more likely it's a problem with MultiECUscan
ABS is communicating to the body computer, the body computer is communicating to the dash to put on the errors
I would not be messing around with fuses or the abs module, we already have one introduced error, we don't need any more, the more you touch the harder it will become
The less we touch the less we have to check
I wanted to avoid going down this rabbit hole altogether, but from eper both panda 1.2 post 2008
We have this
Vs this
Plus the 4x4 normally has pretty unique wiring, the throttle body is only fitted to the 4x4 and dialogic, the wiring to the MAP sensor is different colour and so on
First, not sure if it is the 'post 2008' Panda, as (at least according to eLearn) the change happened in October 2008. So more likely it's the 'pre 2008' one.
Then, the doc I shared is from the 4x4 section. So, assuming this time FIAT was not wrong, it should have the correct wiring :)
Checking the fuse should not make the problem worse, it's the first standard check to do. They do blow sometimes.
But I totally agree with @koalar regarding the 4x4 issue with MultiEcuScan, it has no separate section, there are no specific menus, but as the wiring is completely different, might not be the correct tool to use.
However in the 2WD there's this functionnality for bleading the brakes:
I've read somewhere here that bleeding ABS brakes is also possible without MultiEcuScan, but if the OP's not familiar with the fact that ABS brakes need a special treatment, perphaps there's a lot of air in the system and once he used the brake a couple of times during the test drive it just pushed the air further away and the ABS system stopped to work as it should.
Faulty wasn't there originally, it would be a big coincidence
Air in the abs block, pump self tests, no pressure, fault code
With the absences of working diagnostic it's going to be hard to narrow down any faults
With the ignition on and the car stationary is there any error on the dash, if there is try and clear it by switching the ignition on and off a few times
If you can get the light off
Drive very slowly above 6 km/h but below 12 km/h
If the light comes on now the ABS module has failed it's self test, when it fire up it's pump and opens it's solenoids, try bleeding again
If the light comes only when it's above 12 km/h it's failed the ABS sensor test
You could record the sound of the ABS if you have a microphone
It's quite difficult to hear the ABS pump self test, but it is just possible, no radio, no blowers
See where we go from here, any friend likely to have professional scantool or friendly garage as a favour
That's good
Did you replace any of the wheel bearings
In MultiECUscan try scanning for modules without the adapter
If you using a Bluetooth elm327
And you have access to a android phone
You can also try
If you scan with no adapters connected does it detect the abs ECU at all?
I know on my car's it will detect them all on a scan
You just can't connect to them without the correct adapter
Well, I let the battery disconnected overnight (engine mountings replacement), after connecting the error reappeared immediately. I tried reading via AlfaODB as suggested by @koalar. That thing for some reason always connected to engine ECU. However, after updating MultiEcuScan to 5.3, I was able to see P0571 and U1706 logged in the engine ECU, see attachment. Not sure if this means that the ABS ecu is working, but not receiving output from sensor or its blown.
Start with the easy
P0571 brake pedal switch
If you slipped of the pedal it probably just needs adjusting
Both codes are stored not active, so they should clear
Without the light on you should be able to perform the test above
Does the light come on
Drive above 12 km/h does the light come on
NFR. Brake node
NCM. Engine management node
Communication problem between the ECU and ABS, however canbus errors can be random if the battery been low or disconnected
FAULT COMPLAINED OF
-Engine fails to start.-Gears do not engage (manoeuvre not permitted)
TECHNICAL CAUSE
Switch on brake pedal incorrectly adjusted/defective.
OPERATIONS IN NETWORK
NETWORK BEHAVIOUR STANDARDS TOWARDS THE CUSTOMER
-When this problem is reported and confirmed, reassure the Customer that it can be solved by carrying out a check on the control unit using the Examiner.-After the operation show the Customer what has been done and make sure they are satisfied.
SERVICE SOLUTION
If this problem is reported and confirmed, carry out a check on the control unit using the Examiner and, if necessary, replace the switch on the brake pedal following the instructions in the Operating Cycle below.
OPERATION CYCLE
When this problem is reported by the Customer:
-check the type of fault for the brake lights (failure to come on or on permanently)-check for errors in the control unit using the Examiner
If the brake lights are not working properly and/or there is the "simultaneous" presence of the following errors:
-P1760 in the Dualogic "MTA" system control unit-P0504 (Diesel versions) or P0571 (petrol versions) in the engine management control unit
adjust the travel of the switch push rod on the brake pedal and, if necessary, replace the swith following the instructions in the Service Manual (Op. 5550D10).
Can you clear the light
I am trying to find a way to move forwards
Your scan of available modules is missing a lot such as
Airbag
Body computer
Dash
Not just the ABS, I suspect it's more a problem with either the software or interface, it would be a big coincidence for the whole network to go down just as you were working on the brakes, body computer should at least be up there as it's direct on the canbus pins
Being able to clear the light would allow to know if the error is at ignition on, between 6 and 12 km/h when the ABS does a self test or above 12 km/h when the ABS does a wheel sensor test
Did you replace any hubs or wheel bearings
Hello, after deleting the errors in the engine ECU via MES, the ABS and handbrake light stay on. I also checked the fuse F37 in the driver compartment, no change after pulling it out. Yes, I was replacing the rear diff left seal, so I had to remove and then put back that hub along with CV axle.
