True, although complete propshafts can now be bought new for £260-ish.Older panda increases likelyhood of rear suspension failure.. and potential of propshaft wear.. both expensive headaches :-(
Interesting thought. on the twin air 3000 revs at 70mph is 3000 engine fires. Compared to diesel 2500 revs at 70mph is 5000 engine fires. So i feel the twin is more refined.Hi
Why do you want a 4x4 for racking up m.way miles?
I like TA's but the diesel is better for long term reliabilty (especially as a used purchase)
The reality of Diesel emission charging near Citys is real.. and a major consideration longer term
My TAs are £0 ved and cheap on insurance.. they are fwd only
I see mid 50's mpg..
Wheras the 1248 diesels get nearer 65 mpg.
Biggest issue with the Twinair panda is low gear ratios.. so 70 mph is 3,000 rpm
Diesel is@ 2,500.. it makes a difference for refinement also
I've never seen that logic advanced before. I'll avoid V12 engines for sureInteresting thought. on the twin air 3000 revs at 70mph is 3000 engine fires. Compared to diesel 2500 revs at 70mph is 5000 engine fires. So i feel the twin is more refined.
I drive a 3cylinder smart fortwo diesel at 70mph at 3000 revs is 4500 fires.
Have you considered an early hybrid as they are quite a refined 1.0 l low friction 3 cylinder engine and a 6 speed box.
I tried a diesel on an extended demo and it averaged 78mpg so I would expect 60 in normal running. My TA is more like 40 to 43 in normal running, Going quick knocks it to 35 and going carefully it will do 60, Normal long run to Manchester and back (300 miles) it does 50. I agree with Varesecazy about the steady improvemenmt as miles build and 20K being a milestone. Summer tyres are 3-5 mpg better than winters but temperature will also be in play. I like the 4x4, the ride is much better, the brakes are discs all round, you sit higher up and this makes an appreciable difference, its easier to get in and out and best of all if you have to pull onto a busy road in the wet you can use full power with no wheel spin. The way it handles icy roads is astonishing. That said the potential maintenance costs are scary and more likely than the 2wd. Im thinking of moving to a single car, but cant decide which to keep especially as our 2wd is 5 years older although in just as good condition. Ill probably keep both a while longer. Ideally I should have had a 4x4 diesel but they stopped production just before I started driving them. I suppose you would say my fault for not buying in earlier. I am happier with the TA because of the forum and considerably better understanding of it from teh knowledge shared here, but still feel the TA is only half a step dwon from an F1 car in complexity which makes it service hungry.50mpg is very conservative for the multi jet
Taking it easy at around 63-65 mph in the 1.3 500 used to get 60+ so I doubt the panda will be too far behind that
Its intetesting sound difference when youve worked it out. Put it this way, my wife has always driven 4 cylinder cars until with a rev counter. Chaning gear about 3200 revs She then drove a rebuilt original 500 engine from 1972 by listening to the engine note and not having a rev counter 5500 revs gearchanges every time, i requested she was more gentle with a newly rebuilt engine, to which i was told she was driving it more gently than the normal!Interesting thought. on the twin air 3000 revs at 70mph is 3000 engine fires. Compared to diesel 2500 revs at 70mph is 5000 engine fires. So i feel the twin is more refined.
My previous, 2012 diesel 4x4 easily managed 60mpg. But that was the 75hp, Euro 5 version of the engine.I tried a diesel on an extended demo and it averaged 78mpg so I would expect 60 in normal running…
Yes butvits fun.... Sorry if im adding to it.My previous, 2012 diesel 4x4 easily managed 60mpg. But that was the 75hp, Euro 5 version of the engine.
My short-lived (ie written off) 2017 model and it’s 2018 replacement both struggle(d) to get over 52-55mpg averages across a range of conditions— but they are the 95bp, Euro 6 variants, which do seem to be a little thirstier. 70mph (shown on GPS, which is 75 on the speedo dial) is about 2800 rpm (which is ‘high’ for a diesel)
By the way, I see we’ve ’woken up’ a thread from 2022 in the past couple of days![]()
Well I guess you "canna change the laws of physics" (I probably miss-quoted) energy in = energy out essentially the same engine and drive train with little room for efficiency improvements..?My previous, 2012 diesel 4x4 easily managed 60mpg. But that was the 75hp, Euro 5 version of the engine.
Change that to 35mpg and you should be safe.I have searched but not really found a closer answer for the MJ..
I see most Twin Air generally average 45mpg especially if driving enthusiastically... (Maybe less at motorway speeds)
Will a MJ be much better? (50mpg? 55mpg?)
My current commute entails mainly a motorway run, but that will prob change to a cross country run in a few months..
Or, would the Twin air be more fun to drive and the fuel price difference negate the extra mpg... ??
I can spend up to 6k..
Any difference in maintenance costs would not really affect me as I do pretty much all my own maint, so either would be serviced every 6-8k, regardless.
Some quick number calcs puts the MJ about £100 better off calculated over 20k miles (assuming 45mpg/50mpg and using gov expense claim ppm) so in my opinion, not worth worrying about.. so it would come down to the realistic mpg, better/fun drive, balanced with ultimate reliability over extended miles. (It will get some miles racked up)
Any insights welcome..
Cheers Si.
Edits for extra thoughts..
