Hello All and thanks in advance for any advice.
I have a the above van and get the following problem.
Van drives absolutely fine until up to temperature. As soon as it hits about 85/90° the EML comes on with a P2146 fault then a couple of miles later it will start to misfire and eventually lose all power then cut out.
I then have to sit for 15/20 minutes till it cools down then it will start and drive fine until up to temp again.
I get the P2146 code on a basic phone app using a Bluetooth ODB2 sender so don't know how accurate it is.
First time it happened I pulled into a garage near where I was and they used a Snap On code reader (which I assume would be more accurate)and told me it was particular filter fault code so I took it to a local dpf specialist who informed me it was a faulty Lambda sensor which I have since replaced with a brand new genuine one and fault remains.
I'm lost with what to do and all garages local to me in Durham/North East can't seem to look at it for at least two weeks.
Anybody had the same issue and can shine any light on it for me?
