Thanks for your help! I will give it a try this weekend.
There also seems to be a loose part in the rear door that's rattling left and right in corners. The rear door has a huge plastic cover on the inside but a can't see how it must come loose. Anybody who knows the trick?
Is it just pulling harder or??
Hehe - when I got my Qubo, it too came with the rear tailgate rattle - and after shutting it at first 'it' will slide from one side to the other, then go quiet until next opening of the t/g and we start again. It must be a trim popper that has snapped and dropped down I guess. I will remove the trim for a gander in there to see if I can remove whatever it is. Since I've now got my new V5 with my own number plate on I can change those over so perhaps I'll need to remove it anyway to fit secure bolts.
I bought a trim removal tool from Machine Mart (for when I fitted secure lock plates to the van) and even though it's designed for the job, it's steel (??) and would still mess up the paint on the interior so I covered the prongs with a couple of layers of masking tape to protect the paintwork before using it and it does the job ok. I still had to assist it with a couple of screwdrivers though as you work along one edge at a time to get your fingers in to pop the poppers free.
Just out of interest, the rear wiper on mine doesn't do a very good job of the end 4" on the return sweep - the blade actually sits off the screen when parked. Since the blades on these cars are without backbone (unlike conventional wipers though I think the rear blade has a plastic spine so can't be bent to fit any closer) how do I make that last bit do its stuff better? I couldn't find a new blade for the rear in the Halfrauds catalogue either - eventually buying 2 separate ones for the front but there's just a dash for a part number in their listing booklet.
Sorry for the slight hijack of the thread..
R-V-M
