HI
It is 16V and after almost 1000KM I am putting 3-4 Liter oil.
Engine TypeFIRE (DOHC) Displacement1368 ccFuel TypePetrolMax Power89 bhp @ 6000 RPMMax Torque115 Nm @ 4500 RPMMileage (ARAI)14.6 kmplAlternate FuelNot ApplicableValve/Cylinder (Configuration)4,
Hi Rohitfiat,
so in 1000KM you need to add 3 litres of oil..maybe up to 4 litres,
you are having to add around 1 litre every 250 Km.. that is quite high consumption..,
if there are no obvious signs of the oi leaking onto the ground then it must be
engine wear that is letting oil pass through the cylinders and out through the exhaust,
if you remove the spark plugs does 1 plug look oily compared to the others..??, A GOOD plug should be a clear metal - to - sandy / biscuit colour,
any blackness isn't good;
if it's a dry powder..( soot) that is over fuelling.
of it's black WET - it's oily= that is the cylinder where your oil is escaping,
have a look and let us know what you find,
Charlie
