I want to fit front fog lights to the Scudo. I can get a replacement indicator stalk. Is the wiring present in the van steering column loom for the front fogs?
Why do you want to wire fog lights to your steering column loom when it would be so much easier to use the low or high beam wire from your headlights instead? You won't need a replacement indicator stalk either, just a fuse, relay, soldering iron and some heat shrink for a neat job.
