Technical 2004 2.0 JTD Timing Belt Change
prolecky
Hi all, I have had the main diesel pump spring a leak on my Ducato and as this needs changing I will at the same time change the timing belt and water pump. Any help or advice on do's and dont's with this will be much appreciated. Any pics or diagrams would be great. Many thanks once again. Cheers.
I've attached the procedure for the 230 model should be 99% the same.
  • 2.0jtd.pdf
