Good Evening all
First post on here so apologies if I get something wrong.
I've got a 2003 1.1 Fiat Panda Active which for the past year of ownership has been faultless.
Unfortunately, This morning the battery decided it no longer wanted to hold charge which meant that it needed to be replaced. After getting a shiny new one installed, everything appeared to work correctly, apart from the fuel and temperature gauge.
For some odd reason the needles are facing nearly vertically downwards when the engine is off or just started, The needles appear to have the correct amount of movement as after some time the fuel needle will move to about the 10 o'clock position and the temperature needle to about 9 o'clock. It would appear that the needles are starting in the "incorrect" location almost as if they somehow moved on the axles in the dial.
I should note that the gauges were correct before the battery ran flat and all other systems appear to be working just fine.
Thanks in advance!
Thanks in advance!
