2000 Spyder help
2000 Spyder help
rperkins
i just got my hands on a 1980 2000 spyder that hasn't run for a couple of years. I repaced the electronic coil and was able to get the motor started but it only will idle. Any sugestions as to why the injectors are not opening and delivering fuel would be appreciated.
Derrick
If it's only idling the old fuel may have turned to varnish and some of the injectors are not functioning properly. I would check and make sure the lines are clear. If not, clean the lines and injectors good. You can pull off the lines at each injector and see if fuel is squirting out. Also check the fuel pump.
Derrick
