HornetUK
Established member
Clutch replaced 2 weeks ago under warranty at 19k & 2 years old. Today two weeks later the same noise has returned, creaks when you press and depress pedal slowly. Again sounds like slave. Only does noise after driving for an hour now, was 30 mins last time!
Also when you move the gearstick left towards passenger side it squeeks under bonnet, when hot or cold engine!
Took to dealer they at first said cant hear it, then we went on a 10 min drive and noise came back, tech said it is a different noise to before, (said sounds same to me) and it is coming from behind pedal, something in pedal construction making noise.
Gear noise is a rubber bush that can be lubricated without opening gearbox??? Is that likely?
So its now booked in to try and lubricate all of pedal and into engine bay and the bush next week.
