I have an almost 2.8 turbo Ducato, actually it's a 2005 HDi Boxer but, very similar to the Ducato.
35,000 miles (you guessed it, a motorhome
At high engine loads, >3000RPM, 3rd 4th 5th gears, uphill, full throttle; the engine management light is coming on, and going out again when the throttle is released, road levels out etc.
My friendly commercial garage mech has read the ECU codes, which are:
P0235 - Manifold Absolute Pressure Sensor Circuit
P0500 - Vehicle Speed Signal
P1555 - Brake Inconsistent With Accelerator
U1600 - Coded Start Security
Ive found out that the P0235 relates to the turbo, I've already changed the air and fuel filters, made no difference, so I'm thinking that it must either be a turbo peripherals/hose/blockage problem, or that the turbo is on its way out.
Where should I be looking if it's an actuator etc?
There's possibly a slight turbo whistle at higher revs, is this likely to be an air leak maybe, if so where's the most likely.
Thanks, and apologies for the forum invasion guys.
