General  1998 Uno Mia 1100
Trevoradk
I replaced the can belt because a few teeth had broken off. Started first time after fitting took it for a drive and went better than before.But the following day it lost power and by the time I got home and swiched off it would not start again. I then found that the guide on the rotor had broken so I purchased a new one fitted it. Still would not start. Only to find out the rotor had broken again.
Any ideas what could be the cause as I'm now stumped.
Regards
Trevor
There is a keyway guide on the rotor so it can line up correctly. It brakes that keyway off so the rotor can't be set at the correct pisition
