Technical  1978 124 Project
Sometimes you can swap some of your existing shims around to reduce the number of shims you have to buy.
One way, having measured your valve clearances, is to remove all the shims, measure them and see if you can indeed swap some around. The cam lobes should be fine operating the valve buckets (followers) with the shims removed, when just turning over the engine manually using a wrench.
However, a really smart person would probably have measured each shim before assembling the head and then he'd know which size shim was installed on each valve and could determine if any could be swapped around before he removed them....
(lmao) a really smart person…. I noted TWO of the shim numbers before installing and then just lost my way, so….
I’ll pull them each and note and see about swapping….
Ok: I will have to buy the little tool to hold the buckets / valves down. I’ve tried some things I have and nothing works. Meanwhile, I’m not sure what this is about:
That looks like a crankshaft pulley (although mine has 3 grooves to accomodate a deleted air pump assembly) and I have no memory of there having been an o-ring.
I do have a rubber o-ring that came in my gasket kit - this just seems weird to me (deeply scientific and often incorrect gut feeling).
To remount the flywheel I had to build a box stand for the motor so I could take off the engine stand.
Question: torque spec for flywheel bolts is listed in Haynes as 58 ft lb, while in Pininfarina shop manual at 105 ft lb.
I’m thinking 105? Wildly different numbers…
Could it be there's different size bolts for different years?
Just for fun I asked A.I. and it came back with 65 to 75 "typically " for a 78 further confusing things...to really mess things up in will go check my Chilton manual and add it to this post :)
Yeah I saw a post somewhere talking about 10 mm bolts taking something like 40 and 12 mm taking 60 or so - and these 6 bolts are 19mm! So I went toward 105… seemed like the correct setting and is aligned with Pininfarina…
The other fun bit on this step is that my friend removed the pressure plate without marking it. SO. I’ve looked all over it for a mark but, none seen - so I have just put it on in one of the 3 possible orientations… (shrugging my shoulders).
Chiltons comes in at 61lbs for flywheel to crank bolts for a 78., on the pressure plate you have a clutch pilot tool for alignment correct?
Opps, see the pilot tool! :)
So…. I did something dumb and these pins fell out of my transmission. I’ve read Haynes and Pininfarina and they don’t give specifics on exactly where these two “detente dowels” should reside. YouTube hasn’t helped either…
I’ve taken the 5th/reverse shift arm out (first photo) and stopped to see if the wise folk here could give me some pointers…
I have the plate off the side that carries (with 3 springs) the 3 detente balls. These pins though??
My guess would be somewhere along the gear selector shafts are some machined notches The detents are spring loaded and locate in the notches on the selector shafts
But I’m not sure if thebits you are holding are the selector shafts But I’m detents.
Gearbox rebuilds way more complicated than an engine and less frequently done so not so much info unfortunately
Thanks @Twink80 - I just wonder why they fell out? I had only taken the bottom pan off and the top gear selector (extension) housing. Hmmm.... I'm trying to avoid taking more things apart...
Tbh its difficult to tell what the parts are from the photo, they could also be dowels or a needle roller. I haven’t taken a gearbox to bits for 30yrs so don’t recognise the parts
Its possible that if they are detents they could be held in place by the cover?
The larger one with a groove has quite a specific shape so might make it easier to identify?
Thanks yes - I have yet to find a decent diagram. And no they didn’t fall out of the detent bearing holder (with the cover and 3 springs) as the cover was on and springs / bearings in place after those 2 nuggets appeared. I’ll keep investigating, but may have to remove gears…
Update: Just found this (https://autoricambi.us/transmission-detent-bean---1st-2nd) and this video () so now I'm on the path to discovering where these things go....
Detent beans - video:
So…. I found a 2010 thread on another forum about this AND another detent dowel appeared yesterday! I was laughing after I put things together a 3rd time and dowels just fell out from somewhere.
That’s when I realized I had taken out the sensor that is at the end of the dowel tunnel (I’ll call it). That sensor I believe is connected to the EGR or something - and was a feature of Calif smog fighter cars. Therefore that FIFTH dowel never shows up in the repair manual. So to summarize:
1) they are detent dowels and all ride in the same tunnel that transects the entrances for the 3 shift arms
2) shift arm 1-2 and shift arm 3-4 both have narrow / smaller dowels that reside within them, aligned with the other dowels in the tunnel
3) (this is where I need to test) 1 long fat dowel goes in first and rides on top of the sensor. Shift arm 1-2 goes in. Another long fat dowel goes in. Shift arm 3-4 goes in. Two balls with springs go in to interface with shift arms 1-2 and 3-4. The short fat dowel goes in. Then shift arm 5-R goes in. Last ball and spring goes in.
If the above holds true I’ll write it up and post here - as a guide.
I’ve nearly lost my mind on this. lol
Man, my brain is smoking...good job!
Even pollution junk on a manual tranny,
My 79 is a California smog car (before it was neutered) but mine is an automatic...makes me wonder what's on mine :)
So - just a progress update:
Engine: just needs new shims / valve adjustment, and key nuts torqued.
Transmission: just completed reassembly today with new seals front and rear, new gaskets, new throw out bearing and lower shifter boot. Still will need some attention to the various electronics / sensors (testing, possible rewiring).
Drive shaft: also wrapped and on the wire shelf - that was done with new u joints months ago.
So.
Now what? Body work? Suspension? Brakes?
Thanks to folks here for your guidance this far on this resurrection of machino bambino.
So.
I would try to get it running and driveable then assess what to do next and what you want out of the car
Ive been sorting the bodywork (bare metal respray since last Nov!! It takes ages compared to mechanical stuff
Thanks, @Twink80 - to me, that will mean brakes / suspension. I think the suspension is okay, although I know I'll need to replace some bushings here and there. The brakes I have no clue. Once those are together, then I could joyfully reunite the drive train with the body. Joyfully. I could theoretically put some electrical on it and gas and see if it would crank.
But then I'd have to put the interior of the car back together and probably fill some holes in the floor boards. Yep.
Everything looks great! Something to consider, and we all do things differently on our project cars, if there's going to be fairly extensive welding to the floor pans ect, (I've forgotten the pics you showed) ,
You might want to consider doing that, and the body first, rather than risk the welding spoil one of your 5 new rubber soft brake lines, or suspension parts , new soft fuel lines, new wiring you've installed to get it running ect, doing the body first at this point gives you the opportunity to paint and detail the engine compartment, free of the engine being in, and same at the back with out the tank being in if you get it running first...no matter how you choose to do it the quality of your work shows, it will turn out great!
*excellent* advice! I will proceed thusly.
