Technical 16v conversion / gearbox
Jamesfewell
Hi i am just starting a 1.4 16v conversion in my seicento, is OK to use the seicento gearbox and drive shafts, I just wondered if they are strong enough, the car is used for rallying and it's a abarth box so the low ratio's would be good, any advice would be appreciated thanks
Yeah the standard gearboxes are used during the 16v conversion.
You'll be fitting a decent diff to it if your rallying it right?
Yes definitely fitting a LSD, think I might change the cams as well, I have used the car for rallying before was just very slow, might need some more advice, thanks for your help.
