I'm scared to say it, but your car is almost orgasmic! :yum:
Are all the warning lights wired to go out and work properly (door open light etc) out of interest?
Not gonna forget that comment in a hurry.
I have a second binnacle and dials in development as I mentioned earlier which has some of the warning lights extinguished permanently- ABS, general brake warning/handbrake light, steering failure and general ECU fault. All others work right. The ECU fault light is always on and registers no connection to ABS ECU, ABS CAN problem and no speedo signal. This means I don't have the benefit of early warning, but can connect my OBDII reader to it every now and then and see if there is a fourth error. It's interesting that when there is a catastrophic saftey failure, like ABS, you just get full performance all the time and traction control of course doesn't exist. Also the ECU would normally restrict performance based on the angle of the steering wheel, which is also turned off of course. So to put yourself back in control of your Punto on a track, disconnect the ABS ECU! Steering wouldn't fun disconnected though.
The door open indicators/circuits are all wired up, as are the courtesy and headlight lights, etc. This means a fading interior light and one that knows when you are going to exit after a journey and pull the key. Using the blipper, you can "unlock" the car and lights fade up, dash lights up, etc. before you are there and all that taken-for-granted modern stuff. The "bulb-out" light also works correctly (soooo useful). Also programmable courtesy headlights. Heated rear screen/fog indicators and all other tale-tale lights work, operated by the normal switches.
The speedometer area will turn into a round art space as it won't be used. Not sure what to do with it. Might just leave it "dead" as it is.
