unowho
After a rebuild engine ran fine for 50kms then started to run rough for a bit and now wont start unless with full throttle and even then wont run well. Have checked cleaned and rechecked everything and can only think of the problem being the "Idle cut out device" malfunctioning on the carby. Any suggestions???
Carb gets fuel, has good spark. Timing is sweet. New rings and bearings, seals and gaskets, Cylinder hone (just to clean them up) head shave, valve grind. took a bit to get it running initially and apparently had this problem before rebuild. :bang:
