davidjpb92
I didn't actually check that partYes you can live with the others but No3 is low, however it should still run with those figures.
Just a small point, what is the spark like, is it good and blue, capable of jumping a 10mm gap easily, reason I say this is I notice your ignition amplifier unit on the distributor, it is a type that even when fairly new were capable of failing, so may be worth testing if possible.
Do I check the spark on the ignition ends with or without the spark plugs?
