General  12v socket not working
veryhandy
Hello
I plugged a faulty device into the 12v socket and now the socket is dead( I know the device was faulty as it blow a fuse in another car also), I have checked all fuses and cannot locate a blown fuse.
does this 12v socket have an inline fuse or can someone inform me which fuse box it is in and which fuse number.
Any help appreciated
Hello
I think it's in the engine bay fuse fox if you didn't check that one yet
Thanks Benny, much appreciated, I have found it thanks to your post, it is located in the fuse box behind the glove box (RHD) left side bottom fuse F94 15A
it is so annoying that there is no mention of this 12V socket or fuse in the owners handbook
My 12v socket is dead on my Tipo Easy hatchback. I looked at the sedan wiring layout on this thread and it shows a fusebox for this item in the boot. No luck as its not there but i'm told the fusebox is behind the Glovebox on my car. Any idea how I can get the glovebox out as I'm told its a pig of a job and the handbook shows different. I can't find a wiring diagram for my car anywhere.
Open the glovew box and you wil find two off shaped retaining catch's one on each side that need prising out and a small pin that holds a small bit of string that stops it dropping down too quickly of the right hand side (that's a utter pig to get back into place
You should then be able to get access to the fuse box behind the gloveboxe
If you haven't sorted this out, the fusebox (on my Tipo 1.4) easy is behind the glovebox which you have to take out and the frame around it has to come out as well.
Hello to you!
I have a Fiat Tipo 2017
And for the last week the V12 socket is not working for me,
His lamp does work but the socket does not give power to the charger.
I think it started, after I inserted a screwdriver tester into the socket to test it.
I disassembled the socket today, and checked its connections, and they are fine and have electricity, but apparently the fuse is faulty and it does not give power,
In the car book there is no mention of the fuse of the socket,
I checked in the engine compartment as well as under the steering wheel, and I did not find the relevant fuse,
I read here in the forum, that it is fuse number 94,
I would appreciate it if someone could send me a picture of the exact location, because I can't find it.
Thank you and good night
