Technical 1242 Engine Head on 1108 Block ?
Pras83
Essex
Whilst searching the forum I came across this.
What is the point ? Does it increase HP ?
arc
this is where i stand
Manchester
it'll reduce it if anything, the early (pre may 1997) 1242cc punto heads have smaller inlet valves than the 1108cc Cinq/Sei heads
LanciaMad
Toon
What is the point of that? Does this increase HP ?
I heard its the same head...
OP
OP
P
Pras83
Essex
Oh ok then there's no point really.
I was just thinking of buying a skimmed head on eBay as they are only £40 inc postage. Rather then get mine skimmed. (if my HG is blown)
They are selling both the 1.2 & 1.1 heads for the same price.
So if it was any improvement I'd go with the 1.2 head.
arc
Manchester
do they say which engines they have come off, cos like i say the puntos before 1997 had smaller inlet valves.
no point buying one really though.. just get urs skimmed, its cheaper
OP
OP
P
Pras83
Essex
Arg.
Can't find the auction anymore...
I think i saved it in my bookmarks at home.
arc
Manchester
well yeah, any FIRE head will fit any FIRE engine -but like i said, theyre not all the same!
arc
Manchester
1108 cinq engine (176.B2): Inlet 31.5mm
1108 punto engine (176.A6): Inlet 30.5mm
1242 punto engine (176.A7): Inet 30.5mm
1242 punto engine (176.B4): Inlet 31.5mm
all use 27.5mm exhaust valves.
hth
arc
Manchester
i dunno about the 1108, or the mk2 punto MPI's but the 1242 MPI (punto75 engine), 176.A8 has 31.5mm inlet valves.
but [email protected] has an uno.. which will be SPI, so i assumed he'd only want the SPI's valve sizes!
[email protected]
Your sister's bedroom
Well I'm getting a custom fuel injection manifold made for MPI, and I want to fit the biggest valves possible as it's going to be a N/A conversion.
Do you know if I can get bigger valves to fit from another vehicle?
