Technical 1242 16V Block + 1108 8V head
purf
Established member
UK
Hi all
I have found a couple of threads about fitting an 8v head to a 16v block. wether its 1369 or 1242 block it sounds like it would work, but havent seen anyone with it installed & running.
Im gonna get a 16v engine with a broken head/valve issue very cheap from a spares car!
So im thinking as the bolt holes and channels line up, so i can make a 1242 8v and run it spi. Im not looking for any more power than a normal 1242 - so 60bhp...
I know the pistons are the main difference, but i dont think these will cause any problems? Would they lower the compression ratio?
I have a 1997 1108 8v spi, any ideas if this would have a suitable cam pulley? Or would i have to use the crank pulley & sensor etc from the 1108 block?
Im thinking about getting a punto 75 cam too while i'm at it :)
Your thoughts?
Thanks all
Thanks arc
I was just tempted as were getting a parts car with 1242 16v block. Very good point about the posible damage to the pistons too.
I found this thread b4
https://www.fiatforum.com/cinquecento-seicento/138005-16v-bottom-end-8v-head-3.html
Thanks anyway but I popped over to Kristian & took a look, from what I can tell from the 8v gasket that I have when lined up on a 1368 block the oil & waterways aren't actually too bad a match - Kristian pointed out that when you know better what you are looking at the differences in holes aren't so bad, probably be to restrict & therefore vary coolant flow rate according to piston location & varied temperature.
I guess it didnt work - and thats why theres no more info
thanks :slayer:
dont worry dude, its a no go anyway for me if the compression ratios too low.
I can imagine they probs almost line up, but make a mess of oil and water flow etc...
would it be good for a turbo set up? Not that im planning to go down that route, just out of interest :)
