- Joined
- Sep 14, 2009
- Messages
- 20,105
- Points
- 4,011
Last weekend my exhaust snapped off the bottom of the catalyst. The support clamp I had assumed (stupid I know) was welded to the outlet pipe was just completely corroded away. All that leverage eventually cracked the pipe. Strangely I has no warning. The crack has obviously been growing for a while but there was no undue noise.
Ive welded it up and added support brackets between Cat case and the pipe. I need to make a new pipe clamp but the original bolt had seized into the sump. The threads are stripped (bad enough) but the cast boss has cracked and will need to be TIG welded. The threads are open at the back causing the threads to bind.
I've looked at using the engine steady mounting bolt to link a bracket to the two-bolt exhaust flange. Sadly that has open threads at the back and it's jamming in similar ways. I can't afford to crack the gearbox case so will have to support the pipe some other way.
