Technical 100HP Brake Fluid
Nottingham
My 2008 100HP is nearly due for its first annual service whilst in my possession. I've looked through what service history I have, but I can't find any record of the brake fluid ever being changed :eek:!
I looked in the 100HP handbook supplement and it says the car needs "0.55kg" of DOT 4 fluid. Is 0.55kg equal to 550ml (as it would be with water), or have I got this totally wrong?
If I have got it totally wrong, does anyone know how much brake fluid the 100HP's system actually takes in total, in litres?
I'll probably end up putting myself through the windscreen when I change 6 year old fluid for brand new stuff then!
Was just under 1 litre enough to replace all the brake fluid in the system and refill it to the maximum mark then?
Also, is EuroCarParts/CarParts4Less normal DOT 4 brake fluid acceptable? I assume it is with the 100HP not really being a high performance car.
