radicalroadster
- Joined
- Nov 16, 2008
- Messages
- 2
- Points
- 1
Hi there,
I bort my stilo 1.6 dynamic about 6 months ago nothing but problems,
Ive had the issue with loosing water looked at, compression tested apparently no issues had it looked at time and time again they say its not loosing water but its empty every few days i look at it.
Also loosing oil had it checked out again said there was no issues with it couldnt find any leaks was told its just stilos bad engines :S fail to beleave thats the case tho.
and now its running really lumpy exhaust is blowing although no problems with the exahust, about 2 months ago it started loosing power exhaust blowing but only when it got warm i heared the exhaust then a coil poped. So got that replaced problem went away for a couple weeks and now its back checked the coils doesnt seem to be a problem. exhaust is still blowing and running really lumpy almost like its misfiring.
Any help would be very much appreciated.
From reading around on forums only things i can gather to check are:
Check oil filter is secure
Check lamda sensor
and replace spark plugs
what would you recomend for me to do :S
treat me as a newbe i have a basic understanding how systems work but pretty lost.
Check lamda sensor
