got a 2005 1.6 16v, erratic idle and cutting out sometime it'l start and you can put the pedal to the floor and it will not Rev at all sometimes it revs the nutts off it with only the slightest touch.
replaced the map sensor cleaned the Inlet valve and done map and throttle relearn procedures cleared all codes.
now problem still persists and one code that can't be cleared is there P0105.
read a few of the similar posts around the forum and the net seems I need to test the 5V lines does anyone have pictures/diagrams of which lines and where I need to check?
or any other suggestions what the problem may be?
thanks
thanks
