1.6 16v palio weekender injector light keeps flashing
Sometimes it runs right somtimes it doesn't I have raplaced the complete throttle body , ingnition coil, lamda sensor, air sensor and its still the same and a nother thing is that the fan starts running asoon as I switch the ignition on don't know what that can be
I don't know about that engine/ECU but on many MPI cars the radiator fan will come on immediately if the engine temperature sensor is faulty. A faulty engine temperature sensor is also a likely cause of over-fuelling.
I did change it now and the fan stil starts when I put ignition on and still injector light stays on
I see on my thermostat housing there are 2 sensors I changed the one the thakes the plug with 3 points and next to him there a other sensor aswell by doesn't have a wire attaced and I can't find I wire aswell so I don't know
But can it be if the thermostat is removed that it has something to do with the fan running from the start and the over feuling ?
Ok I'm taking it to a guy monday he siad to me its the cam timing that's not right that's why the sensors is mulfunctionig can it be ?
Disconnect the battery and make sure it is FULLY charged. When you reconnect it, it may reset the ECU to default settings and 're-learn'. Some vehicles do, not sure about Fiats. Some vehicles have a ECU reset method, maybe the Fiat specialists can advise. I had the over-fueling problem, (plenty black smoke, no power), caused by the ECU keeping the injectors open all the time. The ECU also operates the fan. Have the ECU bench tested if possible or try a 'loaner', like call a friend. If the ECU needs fixing or replacing it will cost plenty.....several thousand Rand.
I took it to the guy today that kar pulls A LOT better he said the cam timing where out and he sit it right but the injector light is still on and still over feuling what can I do now ? Fiat charging me R6900 for new computer box but how do I now if its the ecu?
I book the car at people doing wiring and computer boxes so hope it will be fixed after this otherwise I must take it to fiat
Do u guys think that It can be the computer box (ecu) that's broken ??? And can the ecu be repiared or must it be replaced ?
