General  1.2 fire engine throwing alternator belts
sirio
Hi just got my 1.2 and the lad said he just put on a recond alternator but I noticed there was only half a belt left on the pulleys so I replaced it and when the car is running it's pushing the belt off and tearing it so iv replaced it three times still pushes the belts off any ideas
If the alternator was changed then it sounds like it could be the wrong alternator. Do the pulleys line up so the belt can go straight to the next pulley?
If the alternator was changed then it sounds like it could be the wrong alternator. Do the pulleys line up so the belt can go straight to the next pulley? Do you have the same number of grooves on the pulleys and the belt?
I'll run a straight edge across it I was thinking it looks as if the belt is lying at a slight angle I'll try a straight edge and let u know the m8
