Good morning to the team.
I have a punto 1.2 16v with engine number 176b9000.
For 6 months it has been having the following problem. When it was hot it wouldn't start then you had to wait 20 minutes for it to start. What it was having was when you turn the ignition the fuel injection light on the PANEL would come on and it wouldn't start. 5 days ago while it was in motion the car turned off and wouldn't start again. I measured the crank sensor and it was dead. I changed it again and the same thing happened. Before changing the crank sensor when you turned the ignition it cut off the fuel. Now it does. What I noticed now is a mix-up with the lights on the panel. The order when you turn the key is battery - fuel injection, the injection goes off, you turn the ignition and it starts. Now other times the injection doesn't turn on, the battery does it in reverse order.
Anyone who has an idea or is passionately welcome.
Thank you very much
Thank you very much
- Model
- 1.2 16v 176b9000 1999
- Year
- 1999
