This is one of the clips I took off the caliper. I can't find any to match it.
Look in a 1990's.scrap yard..
That was on most of the 90's Fiat range.
Your caliper has tapered edges..
And this clip retains the steel "wedge" That it all slides on?
Type this into ebay..Not sure what you mean ^
This clip was in the pad securing pin. I've fitted normal R clips but they are to long and touch the caliper body so I had to cut them down a bit, the R clips everyone seems to sell don't look any smaller.
Is that on the caliper ?This is one of the clips I took off the caliper. I can't find any to match it.
Can't say I've ever seen anything that small on things I've worked on what it supposed to hold or go on?
Nope, I never seen one like that. On reflection, are you sure it's not a broken and reshaped bit of "R" clip? Looks very likely to me? If so a fitting kit complete with pins, spring covers and R clips are to be had for just a few quid at most factors and on line.This is one of the clips I took off the caliper. I can't find any to match it.
Could you post a picture of the caliper where the pin fits?
Edit. Charlie and John20 - man you're quick! I didn't even have time to look in Big Red's site to find it!
Yup, R clips all the way! First time I did her brakes one of them was siezed and snapped off so I just fitted a complete kit on rebuild - which is why I know they are readily available and cheap! Ahhh! Now I just remembered, Felicity's calipers had two wedges, one each top and bottom which were retained by small wire clips of much the same size but different shape to those our OP shows in the picture. They fitted in holes in the wedges. Maybe it's got this sort of caliper? They required constant attention to stop them rusting and seizing up.The Twisted hoop is typical of 80 /90 era FIAT
@porta will hopefully recall all if this
Is your white panda on R clips Jock?
My 2004 probably was.. But cannot recall my 1986 FIRE and a.. probably those 'twisted hoops'
Yes, R clips to back and front, sliding wedges top n bottom of calipers, on some, or a raised bit to front of wedges and R clip to rear so that it wedge didn’t come off calliper…simple, easy and fitted in secondsThe Twisted hoop is typical of 80 /90 era FIAT
My 2004 probably was.. But cannot recall my 1986 FIRE _ probably those 'twisted hoops'
That's what I tried describing yesterday..Yup, R clips all the way! First time I did her brakes one of them was siezed and snapped off so I just fitted a complete kit on rebuild - which is why I know they are readily available and cheap! Ahhh! Now I just remembered, Felicity's calipers had two wedges, one each top and bottom which were retained by small wire clips of much the same size but different shape to those our OP shows in the picture. They fitted in holes in the wedges. Maybe it's got this sort of caliper? They required constant attention to stop them rusting and seizing up.
Sorry Charlie, I just missed your post of yesterday (grandchildren overload). Not trying to poach I assure you.That's what I tried describing yesterday..
Funny how this stuff comes around again isn't it..
