Technical '06 Panda crank sensor issue.....
It's obvious that it's ECU side because it's completely dead at ignition off (no ECU power) that's how i figured it out but one more question priming is enough or want me to crank?
Nothing on both signals on positive and negative while priming and cranking aswell
Can i try the same on the injectors just to be sure? Or it won't work?
No spark
No click
We already know the answer
Doesn't work on a running engine as the ECU switches the injector off I have tried
Unsure about while cranking I'd guess it should work but that's a guess
But before deciding on that, the guy that checked it said that it is functional so shouldn't the BCM be faulty?
We don't know what's wrong
We have no errors that should stop the car from running
The immobilizer is off
We have a crank signal
We have power to the coils and injectors
We have no communication whatsoever to the injector or coils from cranking or the scan tool
Its unlikely to be either as it works sometimes
Ok so the ECU is reading the CPS signal and giving RPM feedback normally on the scan tool
I am still suspecting the cranksensorwiring. It may give the right signal for the revcounter, but not the signal the ECU needs.
gr J
gr J
We tried to eliminate that possibility by activating the injectors from multiecuscan, without cranking
The relay to power the injectors energises
There's is battery voltage going to the injector
But there's no ground side switching at all
The injectors test fine manually grounded
Where is the ECU taking it's ground?
Try an extra ground maybe?
Been done and tested
Although there are several different ground pins on the connectors
Maybe we need to go through them all with a load incase one is floating
Seems like someone has been here before as there's two bolted to heatsink
The dualogic confusess things, it probably cuts the ECU under certain circumstances, as far as I know
Let's start at the begining
I have to make do with what wiring I have, the dualogic 2008
Is this cable present
From the ECU to the chassis leg
As for this ground you did mention from below the fuse box no there isn't there's these 2 that i previously told you about one is inside the upper loom and the other goes to a ground below the windshield and they are merged together
There's got to be a clue there somewhere
Fiat didn't screw a bolt in without it doing something
My guess is the one under the windscreen should go under here
