RDM1
Established member
And btw is this overheating warning possibly coming from the sensor? Or electric malfunction?
Yep I tried them all they all activate and the tick is audible coming straight from the injectors themselvesWhen you turn the ignition on and the pump is priming
With the test light on battery negative if you touch the injector ECU signal side
Does it click
GreatYep I tried them all they all activate and the tick is audible coming straight from the injectors themselves
Gonna check that but consider it functioning because the car when it decides to run it runs so they're definitely functional but still I'm going to check themSame with both coils
You should be able to see a spark the same way
With the test light on battery negative if you touch the coil ECU signal side you should spark on a grounded plug
Yep we don't know how it's wired internally inside the ECU
It's not unknown for one shorted injector to stop them all
I doubt a faulty coil would stop everything, but it needs eliminating, especially as the coil primaries weren't identical when we resistor checked then and we didn't check the secondaries at all
This way we know if its fully functional and can move on quickly
No otherwise they would be on permanentlyDo you mean that it's possible that the ECU has an internal short circuit on an injector or coil pack?
Not what I expectedNo spark at all on both coil packs tried all 4 wires there is no spark although the 12v tester is lighting up
