i recently bought a stilo multiwagon jtd 80 it was running but had excessive crank case pressure from over revving after turbo failure .
I bought a known good engine and turbo and swapped injectors pump loom and sensors from original engine on to new engine as the new engine was cf3 but the car is cf4 setup it turns over and over but no start sometimes it gives a kick as if its going to start but it shows up P1320 and P0235 tested the crankshaft sensor and its reading 960 ohms .
I have also changed camshaft pulley as its different and put original camshaft sensor aswell but no change .
any ideas are much appreciated before i pull my hair out
