- Aug 14, 2011
- 258
- 80
Hi folks
Latest in what seems like a constant stream of faults with my ageing Stilo (1.4 16v), but this time something which has put her off the road.
Changed the dipped bulb on the passenger side, usual method for me - remove battery, loosen off the battery box so that it can be moved a bit to get into the bulb etc, changed bulb, put it all back together again and then... ...... won't start. Starter turns engine fine, but no sign of even wanting to fire up and also nothing else electrical works including no lights, nothing on the dashboard, nothing. Only other thing happening is constant high pitch noise and intermittent clickety click noise which seems to be coming from the ecu - this even when the key's not even in the ignition.
Any ideas at all?
Tia.
Any ideas at all?
Tia.
